no need for bypass diodes @12v
  • fivewin
    • Aug 2016
    • 203
    I read here: "Bypass diodes are not needed on 12-volt systems (optional on 24-volt systems), and should always be used on 36 volt or higher systems.
    Is this true?
    https://www.solar-electric.com/learn...ical-tips.html
    Read wrong, and it's a poor article. If you use a charge controller built in the last 20 years, it provides the blocking diode function automatically.
    I've not heard of any install in the last 20 years where any diodes needed to be installed. Sometimes, bypass diodes in the panel J-box will fail, and they need to be replaced.
