You have one MPPT controller.
2 panels
Maximum Power: 130 watts
Tolerance: +10%/-5%
Maximum Power Voltage: 17.6 volts
Maximum Power Current: 7.39 amps
Open Circuit Voltage: 21.9 Voc
Short-circuit Current: 8.02 amps
2 panels
Maximum Power: 230 watts
Tolerance: +5%/-3%
Maximum Power Voltage: 29.1 volts
Maximum Power Current: 7.90 amps
Open Circuit Voltage: 36.7 Voc
Short-circuit Current: 8.40 amps
Am I right ?
I would put on old panel, and one new panel in series, and parallel that with another old & new.
17.6 volts @ 7.39 amps & 29.1 volts @ 7.90 amps yeilds 46.7v @ 345 watts each string, or nearly 700W -20% real life losses = 550w into the batteries ! ( @ 15V = 36amps
adding up nameplate and deducting 20% gives 576 watts So you only loose 26 watts in the amp mis-match. Or you could buy another $600 charge controller
2 panels
Tolerance: +10%/-5%
2 panels
Tolerance: +5%/-3%
Am I right ?
