Per my inspector, I need to make changes to the grounding connections at my roof disconnect box. The system is all installed and this box receives the trunk cables (two branch microinverter system). So, the hot wires will be live (unless I want to work on the roof in the dark). My plan is to work late in the day when there is no direct sun on the panels, but I think they still generate power from ambient light. So, I'm told people put blankets on the panels to block the sun.
Questions: are there other safety precautions I should take? I may not be able to 100% cover the panels due to the array size/shape. What should I do in this case? Should I touch the hots to the ground in order to dissipate any charge in the system?
