Been doing my research........but alas there's no exact match to the system setup I wany to create to be found. So, let me pick your brains so I can get the warm feeling in my gut to proceed. Here goes....
2016 Keystone Bullet247BHS
4-Trojan T-105 Batteries
2-100 watt Solar Panels
400 Watt Wind Turbine
2- 30Amp Charge Contoller
12V-1000W/2000W peak Pure Sine Inverter
12V-2000W/4000W peak Pure Sine Inverter
My goal is to not have to use the generator or plug in while still being able to use all electronics and a 900Watt mini split AC unit.
My thoughts are to wire the four batteries in series/parallel for 12V @ 450 amps. Then one solar panel and the wind generator will be wired with one controller while the other will wired to the other panel. Both controllers then wired to battery bank. The bank is also wired so that I can get a charge when driving on the road or when plugged in as well.
Next I have both inverters coming off the bank. The 1000w/2000w will have just the AC unit plugged into it. The 2000w/4000w will have the 30amp RV line plugged into it to power everything else. The refrigerator, coffee pot, water pump, etc. Both inverters will have separate fuses.
So my question is, aim I day dreaming or am I onto something?
My confusion is with wire gauges and the inverters/ charging. For wire gauges, what sizes should I really be using. Are the stock wires that came with each inverter good enough? I mean if they can't handle the load why send them? And with the inverters, do I have to worry about current control while using them when the panels/wind turbine are plugged in and charging? I mean I'd like to be using the AC at the same time my batteries are charging. Also, is there any reason I couldn't keep the battery bank and charge controller in the same box?
