Hi everybody,
i m writing from Marmaris Aegean sea coast.
i want to install solar panels on the stainless steel arch of my sailing boat.
the temperature (which effects the efficiency) is always high in the summer time and also the shade of the boom and mast will be on the panels most of the time.
there is 2 alternatives
1- Using 80 watt X 3 panels (wurth - cis) (Vmpp 35 v - Voc 44 v - isc 2,5 a - Vsmax 1000 v)
2- Using 135 watt X 2 panels (solar fabrik - polycrystalline) (Vmpp 17,94 v - Voc 21,86 v - isc 8,08 a - Vsmax 1000 v)
i will connect all the panels parallel.
i have 100/50 Victron MPPT and 2 X 210 amp 12 v dc gel battery.
if i will use 1st alternative the calculation will be as follows 80 x 3 =240 watt 240 /35= 6,85 amp before MPPT 35 /14,4 v dc(for charging gel battery)= 2,43
6,85 amp X 2,43 = 16,64 amp
2.nd alternative 2 X 135 = 270 watt 270 / 17,94 =15,05 amp before MPPT 17,94 / 14,4 vdc = 1,24
15,05 amp X 1,24 =18,66 amp
if i will install first second choice, then i must use thicker wire from panels to MPPT controller.
Also, in the first one i will use 15 amp 55 volt dc circuit breaker between panels and controller. in the second one it will be 25 amp 30 v dc.
The higher voltage panels are cis panels and because of the high voltage they will effect less than other polycrystalline. (if thats true)
Please inform if am I wrong.
Thanks ...
Thanks ...
