Hi all, i have aquired 4x Suneka 240w Solar panels, i would like to have these standing in my garden wired to a Grid Tie Inverter which i can plug into a wall socket to help get my bills down, here are the panel specs...
Max Power:240watts
OpenCircuit Voltage (VOC):36.8v
Max Power (VMP) 29.7v
Max System Voltage: 1000W
Short Circuit Current: 8.06A
Max Power Current (IMP): 8.09A
Max Series Fuse Rating: 15A
Im not sure if serial or parallel is the way to go?, ideally i would like to have all 4 panels connect into 2 cables via the MC4 Y adapters and then run 15feet to my utility room and a fuse and then to the 30/36V Grid Tie Inverter (1000w), what size fuse would i need? Would i be right in assuming a 40Amp fuse with each panel being rated at 8Amps x4 = 32A?
This is the Inverters Spec...
Rated Power 1000W
Solar Panels 60/72 cells ; 30V/36V
DC Input Range 20V-45V
MPPT Voltage 26-36VDC
AC Output 120V(90-140V) or 230V(190-260V)
Frequency 48Hz-62Hz
THD <5%
Power Factor >97.5%
Stand-by Power <1W
Certification CE RoHS
Many thanks for any advice
Cobs
Max Power:240watts
Rated Power 1000W
Frequency 48Hz-62Hz
THD <5%
Power Factor >97.5%
Stand-by Power <1W
Cobs
