Problem in Trannergy Inverter
  • nalinpc3
    • Nov 2013
    • 11
    I installed the trannergy 3kW inverter in one of my project. But it's giving poor performance. chart.jpeg
    This is a single day power chart. I checked all connection, wires, and all possible things. But still same result. What would be the problem. I have installed several system but only this is giving this result. Pls help me to sort out this
    i suspect it's overheating and cutting back till it cools off later in the day. is it exposed to the sun ? does it have good cooling airflow around it ?
    • nalinpc3
      • Nov 2013
      • 11
      no
      It's having good air flow and it's not exposed to the sun and the temperature also maintaining good. It's totally normal. What if the MPPT is not functioning properly
        First thing I see is jagged peaks and valleys. So it's a cloudy/sunny day. 10% to full power and back, every 5 minutes.
        2nd is the dip in the middle, which has got to be thermal. If the inverter is ok, then there are a bunch of panels or connections that are going bad in the heat. Are these NEW panels, seconds, used ? One dud would barely be noticeable, but I'm seeing half dozen bad ones cutting out in the heat, and recovering as it cools off.
        That's the only way i can explain the power dip. Or - check the connections in the boxes with an IR thermometer. Maybe a loose wire is heating up and going bad at high power.
        • nalinpc3
          • Nov 2013
          • 11
          OK I will check. They are brand new and even I change the wire also. But still the same But as I observe the voltage is steady. Anyway I will check the connections. thank you for your help
          • nalinpc3
            • Nov 2013
            • 11
            You can check online through this portal. give me some relief
            • nalinpc3
              • Nov 2013
              • 11
              http://log.trannergy.com/Terminal/Te...52&key=7HE6G89
              and this is mostly happening all the time but in sunny days it will shows more fluctuations.
              If I don't. Have a thermal scan what can I do for finding bad connections.
