Hello to the group and good day.
I had a 300 watt grid tie inverter handling 2 solar panels connected in parallel producing about 70 watts. It was plugged into a house/grid electrical outlet through a heavy extension cord. The extension cord had 3 female outlets; the inverter was plugged into 1 of them. I needed to use my air compressor and I plugged it into one of the other outlets of the same extension cord. After using the air compressor, I noticed that the inverter had stopped functioning. I've checked the fuse and all other connections. It was working before I connected my air compressor to the extension cord. Is it possible to damage the inverter by connecting a high draw AC load in parallel with the inverter AC output? It appreas that the extra load cooked it somehow. If so, I will need to be careful to not connect anything else to the circuit while the inverter is working...Thanks for any thoughts.
