I have two panels that are giving strange results.
On eac panel the open circuit voltage is about 41v and open circuit amps are about 5a.
The panels output up to around 5 amps each when used with a MPV solar controller connected to a 12V battery bank. However, when connected to a MPPT controller the panel output drops to about 2.5 amps each. I have confirmed this with both the solar controller meter and a clamp ammeter. We even tried a new MPPT solar controller to ensure that the controller was not the issue.
I believe there are no issues with the bypass diodes.
My real problem is the 1/2 output when connected MPPT. I should be getting up to 30 amps on a 12V system but never get above 15 as for some reason the panels seem to fail under load.
Can use some help. Do you need more info.
