I'm wondering if it is possible to add 7 kw more to an existing 130 kW system, being combined in a separate combiner box and landing it on the main DC busbar in the central inverter?
With the existing system using (2) 350A fused circuits coming into the DC bus of the inverter, and the additional circuit being strung to the same voltage as this, will I have a problem fusing the 7 kW addition with a 40 amp fuse, and landing it to the common DC bus in the inverter?
My concerns are the possibility of back feed from the existing large PV strings, to the smaller 40 amp circuits.
I'm using Uni-Solar PV-128W laminates, in strings of 11. The inverter is undersized now, so this is not a problem.
I would appreciate any input on this.
Thanks!
Thanks!
