OK, here's question #1. I live in the Phoenix area and my electrical service panel is on the outside of the garage on the west wall of the house, which means it is subjected to direct afternoon sun which can be brutal here especially when it's 115 in the summer. I am considering several 5Kw to 6Kw systems with a single grid-tied inverter.
The question is, would it be wise to install the inverter inside the garage - on the wall directly inside the service panel location - with conduit through the wall for DC feed from the PV panels and AC feed back to the service box? This would keep the inverter out of the direct sun and in a much lower temperature location as the garage is cooled. Or is this illegal since it places the inverter disconnected switch inside and away from the service panel? Would installing a shade awning be a better solution? Or am I just being overly worried about heat?
Thanks!
Thanks!
