HI all
first of all let talk about my solar equipments I have.
I have
1-4 x 250 W 38v (open circuit) 8 Amp
( I connect each two in parallel ) and then connect this two in series to have 48v system, ( when I test it with meter it give me 64v) which I think is ok.)
2- 4 x 12 volte gel batteries ( also same I make series and parallel connection to have 48v gel batteries, ( now when I chick this new batteries with meter it shows me 52v which mean it almost full) the total power now should be 9600w (200A * 48V)
3- 1 x Mppt controller
** for connection I connect the solar panel to mppt and form mppt to gel batteries.
** now before I start charge the batteries I connect the batteries (48v) to 120 AC inverter to switch ON 1000W light , and yes the light keep work for 7 hours . and after 7 hours it inverter start beep that indicate there no enough power to switch on the light .. and thin the inverter switch off .
when I chick the batteries it show me 44v rather than 52v when it is new ..
now I need to charger it , when I put my solar panel in clear view of sun and make mppt start charge .. it show me in mppt screen it start charging the gel batteries and the output power for charging is 700w and the current is almost 14-15A.. which is great in my case and enough for me ...
but after 30-45 minutes it decrease to 4-5A and the power 100-200W ..
I again discharge the batteries and agian try to charge it in different time of the day and yes it start with 12-15 A 700 w and thin after 30-45 minutes it start to decrease to 4-5 A 100-200W .
I use different controller it give me same reading of power and current ..
there no other connection in my system it is direct connection , I only use small dc breaker to disconnect the pv cable from the controller ..
where is my problem , it is batteries or controller ????? please advice , i already spend more than 4000$ in this system , again please advice ??
regards
I have
regards
