I have 4 battery's and wandering if it will be better to hook them up in series or parallel. I have them in parallel right now and that is 12 volts but isn't it better to have them in series to get 24 volts . It would power lights and other things better.
12 volt or 14 volt
12 volt or 24 volt
Depends on your loads.
If you have a bunch of 12V appliances, you know the answer
If you have stuff that runs of 24V, go with 24V
If you are running things off an inverter, then, generally, the higher voltage choice is better, because you have less amps in the system to create loss, and still retain the same watts. You will need an inverter for the right voltage.
MikePowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike , I just bought a 60 amp inverter to replace the 30 amp one.
I need to figure out if you can go + - +- on the solar panels. I have everything in parallel right now . I don't think I'm done yet because I have a DC breaker switch coming.
Thank you for your help.Comment
You can hook panels in series + - + - + - to increase the volts, but be careful, your charge controller can only accept so much voltage before the magic smoke comes out.
If you don't have an MPPT Downconverting style of charge controller, you may not want to go more than 20% above your battery voltage, as the power will be lost/wasted.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I have a Morningstar 60 Amp tristar charge controler. Youn can ajust your rate for 12 , 24 , 48 volts . I was looking to see if it was sine wave or not and I can't find anything. I have a good one for you. What is the PWM battery charging algorithm ?
I have found on the web sight it provides it is MPPTLast edited by DeltaFox 25; 10-28-2009, 04:47 PM.Comment
Morningstar makes 2 models of the 60A Tristar.
Original PWM $200 http://www.altersystems.com/catalog/...48v-p-363.html
New, Dec 2009, MPPT $561
PWM is Pulse Width Modulation, where the PV output is connected to the battery vi a FET, and the charge is controlled by Modulating the On time. Touch the wire, remove the wire, touch the wire, remove the wire. Like controlling engine speed with the fuel pump.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Yes , My charge controler was $198.88 and I got the remote Temperature probe also $ 28.16. I needed a better one then I have already and it is a sunforce 30 AMp . So mine isnot a MPPT ,o well, It looks like I payed 5 or 6 dollars more.Comment
