Back feed thru a fusible disconnect
Well if have you have panels without a way to totally disconnect their power leads then set a fire and you will see for yourself. There has been more than one occasion that someone got shocked by solar panels due to the lack of a disconnecting means. It is now a code requirement.Comment
The issue is the panels are on the roof. Disconnect must be accessible (near the meter)Well if have you have panels without a way to totally disconnect their power leads then set a fire and you will see for yourself. There has been more than one occasion that someone got shocked by solar panels due to the lack of a disconnecting means. It is now a code requirement.
Fire department shows up and turns off the disconnect. Now DC power is off to the inverter but is still alive and well on the roof from the panels to the disconnect. the only way to turn off the voltage would be to either cover them or short the entire array out which would drop the voltage to 0
However the fire department isn't going to do that.NABCEP certified Technical Sales Professional
If there is no way to disconnect the panels and isolate the power from them the FD is not going to risk the chance of electrocution to anyone using a hose to put out the fire. Trust me when I say the FD will find a way to make sure there is no live power cable anywhere they are working. I have seen the FD in action and they will find a way to de-energize all power feeds to a building before they will try to put it out with water. If that means tearing the panels off the roof using their ladder truck then so be it. If they can't find a way to kill all power then unless there is someone that needs to be rescued they will let the building burn. It is for their own safety.The issue is the panels are on the roof. Disconnect must be accessible (near the meter)
People first, property second. I believe Sunking when he states they will use their axes on the panels.Comment
So you would take a metal object and start smashing live electrical parts? potentially exposing live electrical parts?If there is no way to disconnect the panels and isolate the power from them the FD is not going to risk the chance of electrocution to anyone using a hose to put out the fire. Trust me when I say the FD will find a way to make sure there is no live power cable anywhere they are working. I have seen the FD in action and they will find a way to de-energize all power feeds to a building before they will try to put it out with water. If that means tearing the panels off the roof using their ladder truck then so be it. If they can't find a way to kill all power then unless there is someone that needs to be rescued they will let the building burn. It is for their own safety.
Letting the building burn is more like it. If the building is that engulfed it is pretty much too late anyway.NABCEP certified Technical Sales Professional
I think the FD (which I am not one of) would first try to kill all power to the burning building no matter what is it constructed of. If they can't guarantee that all power is off then they probably would just let it burn. It doesn't have to be fully engulfed but if they only have water as a suppressant they won't pour it on an energized circuit. It's too dangerous to them.Comment
