  • CAP1992
    • Jul 2018
    • 9
    Greetings from central ca
    hello solar panel enthusiasts . I am a DIY off grid solar seeker who is trying to create clean appreciative energy for himself and it's been quite the dangle .
    Equipment is as follows in pictures.
    They are four individual panels not to different in specs but not identical.
    theyre wired in parallel
    i have four harbor freight 35ah batteries in series to create 48v battery bank (planning on upgrading soon)
    i also have an eBay mppt charge controller (see pics )
    And a pure sine wave 1500watt inverter at 48v
    please let me know what your guys opinion is. If I'm out of line with my experiments
    If I should have my panels in series instead of parallel under a 48v system
    what I should be changing etc thanks again guys!
    30V panels in parallel are not going to charge a 48V battery bank.
    If you wire 4 in series, you will likely be over the Voc limit for most charge controllers
    2 in series will only get you 60V. and that's not enough always, for a full charge (not in a 6 hour solar day)
    • CAP1992
      • Jul 2018
      • 9
      THANK YOU. That makes perfect since! I will work on that .. and the charge controller I bought was an 80amp controller capable of more when running at 48v so I'll see if it can handle it like you were saying In a series string . We're hitting triple digit 105+ weather here in cen cal all week and it's been that way for about the whole month I'm trying to take advantage of all the sunlight I can get .
      My charge controller stopped working suddenly not sure if it was because I had the panels in parralell or what but I'm working on getting another one and adding fusing to my equipment because I don't have any fusing in between my gear .
      But it thanks again that's exactly the kind of info/advice i was looking for and could NOT find anywhere else.
        Charge Controllers have an Input Voltage spec. Most 60A and larger controllers have a 150V max input.
        • CAP1992
          • Jul 2018
          • 9
          You are good buddy. Just looked at the specs and yes you are spot on. My controller is actually a 60amp as well. It may actually have not fried what I think happened is it got a little bit of sunlight where I repositioned it and it messed up the LCD display. I use to hate when that'd happen to my voltage meters after a couple of hours in the sun. Contemplating buying a new charge controller or just a charge controller monitor if they have one for my controller .
          So max VOC for my 60a mppt is 160
          thatd put me at a little 120 volts in a full series array
          would this be safe to try?
            Voc 37V x4 = 148v @ 70F
            If it ever gets a bit chilly, that voltage will go about 20-25% higher and 177V is in "Fried the Controller" territory.
            You measure your power voltage as Vmp, but the controller really cares about the Voc
            • littleharbor
              • Jan 2016
              • 1998
              Basically, You can wire 3 in series for a voltage high enough and safe enough for 48 volt battery charging. Your other option is to get 2 more similar panels and wire 3s2p, two strings of 3 panels.
