Hello from Shepherd, MI we are retired and living off grid. We have a single floor ranch home 2,068 sq ft, with propane, heated water floor, and solar energy. This is our first winter in our new adventure, and I have lots of inquiry from anyone living in the cold areas off grid and taking good care of our solar panels. Looking forward to hearing from this group. I am bringing my horses to this new environment next summer, and learning alot as we go! Merry Christmas to all.
Most Popular Content
Newbie Off Grid from Central Michigan
Hi hrstang and welcolme to solar panel talk if this is your first off grid solar adventure .....well buckle up your in for a cool adventure...cheers -
For winter, with snow and ice, you would want the panels high enough that snow sliding off, does not pile up and block the bottom row of panels
Or sliding snow does not rip your gutters off.
Best in winter, to increase tilt on panels so snow does not stick, and you gain some reflected light off the snow field in view of the panels.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
While adjustable tilts are not always easy to pull off or maintain in winter, they are close to a necessity if reasonable solar array performance is to be expected during that time.Comment
Increased winter tilt will also lower the solar incidence angle on panels and in so doing increase the amount of direct irradiance on the panels. That will increase the performance more than any added enhancement from the snow albedo, particularly during the shoulder months when snow cover may be absent.
next version will have tilt easily adjustable for season. Keep panels several feet clear of the ground to
avoid snow blockage, and leave a snow gap (6" to 8") between upper and lower panels to minimize
clearing efforts. Bruce RoeComment
So true, this is the only time of year my fixed panels cannot hit peak power; 20% production loss. The
clearing efforts. Bruce RoeLast edited by J.P.M.; 12-13-2017, 12:10 PM.Comment
This 28hp AWD snow blower maintains some 1200' of paths to get to everything, besides clearing
the driveways. The worst I've seen is 4', just takes longer. Bruce Roe
BloConv4.JPGComment
Snowshoes!. No sense moving the snow when you can walk on top of it. I highly recommend the US Army Surplus magnesium snowshoes http://www.armysurpluswarehouse.com/...oe-1-pair.html the prices are all over the place so make sure you do some searching. I do strongly recommend an after market set of bindings like these https://iversonssnowshoes.com/produc...prene-binding/ as the original army versions are probably why they are surplus.
I use a plastic snow rake on my panels to clear the snow. Some folks go fancy with softer rakes but I have three different brands of panels of various vintages and no damage is visible.
By the way be real careful raking panels from below. When the snow lets loose unexpectedly the weight and impact of the snow is lot harder than you would expect..
Just budget for extra fuel for the generator and don't pull your batteries too far down.
As I write this from San Diego, it's Dec. 13, At 1430 hrs., the sky is cloudless and the air temp. at my array on the roof is 83 F., with an ambient ground air temp. of 77 F. Buffalo's a great place to be from, where it's currently 18 F. and about to snow some more.Comment
Assuming a ground mount. With landscape mounting and snow gaps between higher panels,
there will be no avalanche, and not much snow piling up in front. Bruce RoeComment
Thanks for all the great ideas and comments. We are doing well, and our solar panels are stationery on ground mount with the most advantageous angle year around. Less up keep for us and hubby keeps them clean with a special soft foam home made rack of sorts. No problem keeping snow off the bottom as it slides off we just plow it away. He can strategically tap the foundation structure lightly and snow falls off as well. Enjoying the sunny days and loving my generator on the gloomy days.Comment
