  • Feisal
    • Jan 2016
    • 70
    forget the shade hours, you've easily wasted more electrons talking about them, Just total up the good sun hours and you will be close enough.
    I've had a couple days this winter, where the clouds were so heavy, I got only a couple watt hours of harvest. Shaded panels produce no usable power in my experience.
    (522 wh for the whole day, off a 5Kw array).
    Thanks Mike. You are right. Simple and clear.
      • 15051
      For my part in this, I apologize for sharing some information and opinion I thought correct, and perhaps informative and helpful. In the future I'll do my best to avoid wasting electrons.
      • PNjunction
        • Jul 2012
        • 2179
        Originally posted by Feisal
        How to calculate for shade hours? I mean do you just
        cut down the insolation hours? IDK. Shade is not like total darkness.
        Unless you are designing for a space-mission, here on earth we just throw-away those hours prior to and just beyond the "meat" of solar insolation when calculating, even if there does seem to be *some* minor current flowing.
        In the solar-biz, we always try to give ourselves a hedge, and be conservative in design and sometimes, expectations.
        • Feisal
          • Jan 2016
          • 70
          Originally posted by PNjunction
          Unless you are designing for a space-mission, here on earth we just throw-away those hours prior to and ....
          Thanks PNjunction. Liked your simple explanation.
          Cheers.
          • Feisal
            • Jan 2016
            • 70
            Originally posted by bvmm
            The amount of cloud/rain/snow shade is highly dependent on the location, and also dependent on the location. IMO PVWatt does a pretty good job of including this. I did some analysis of the. ... .
            Thank you bvmm, sorry for the late response, I overlooked it, my apology. Although I have no clue about the graph you attached, I appreciate your help.
            • Feisal
              • Jan 2016
              • 70
              Originally posted by Scott Sousa
              http://pvwatts.nrel.gov/
              I am just saying that PV watts plugs in a 3% shade as default- without proper tools it is difficult calculate shade accurately.
              System info is the third page after you type in the address. there is a little picture of a calculator about the middle of that page- next to the line "system losses". click on the calculator and a new box will open. this is where you can adjust the shading amongst other things.
              Thanks a lot Scott for your help and guidance.
              • diogenes
                • Jul 2015
                • 175
                I would take a good look at NREL's SAM It actually has a shading model which allows you to define shade objects and their dimensions, a little harder to use than Pvwatts, but I think the effort is worth it.
                  • 15051
                  Just takes time to learn, but can give perhaps useful results. Without the learning curve knowledge, design results can be similar to giving a hammer or a butcher knife to a 2 year old.
