Normally, you would use a DC-DC converter, but those get expensive after you pass the 100W mark.
Instead, look at the other Xantrex inverter, the XW series, they have 2 48 V models, the XW4048 4KW and the XW6048 6KW
You will need a minimal battery bank, but 4, 12V deep cycle batteries would do it, $400 for that.
They can do grid tie, and have all sorts of adjustments for sell voltage, peak shaving and such.
What is your wind gen ??
Bulldog Before you even think of doing anything you would need to find the average kwh put out by the wind generator at least over one month..
You may find it does not put out enough to justify buying a DC to DC converter.A converter that can output over 400v is going to be expensive,, Another problem as its a GT system connected to the power companies grid you will be connecting an uncertified item in the system,,
Hello, I am not the one to answer your question but good luck and please let us know how it all goes.
The level 4 does not mean too much in itself. I live in an area with a commercial wind farm a few kilometers away and decent down on the beach but where I am located there would be no hope.
A good tower will be important. The Danish Wind Association site has a good tool to see the effect of elevation as regards getting up into better wind.
