I live in Alaska. Winter is usually no colder than 10° F, summer no warmer than 75°F. I have a pair of Concorde PVX 1040 Tbatts (12v 100ah) wired in parallel. The batts will be in the living space of my cabin (spare room), in a batt box. The box will be vented. The batts will be charged with an Iota DLS 45 over the winter and solar in the summer using a Mppt CC. I have been trying to do some research on the best/most practical way of venting the batt bax. I have seen:
- two holes, one high one low, pvc to the outside
- copper tubing, one large diameter, one small. The smaller pipe inside the larger. The small pipes goes almost to the bottom of the box, the larger goes to the top of the box
- power vent,venting outside via pvc
I am leaning towards the power vent. I understand that fan needs to be monitored to ensure it is working. I am home most of the time so that is viable.
So I have two questions. First, what would you recommend for venting? Second question, should I build an outdoor box knowing it would not be heated? I am not liking the idea of an outdoor box due to the temp but maybe I am being to worried about that.
Thanks and have a good one
