Anyone know or have discovered the best way to keep birds away from solar panels?
Most Popular Content
Keeping birds away from panels
Giant wind turbines and/or very large concentrating solar arrays seem to keep the bird population down some, but at the expense of pissing off the tree huggers. I'd try those.
Seriously, washing seems to be a practical approach. JUST DON'T DO IT WHEN THE SUN IS SHINING. EARLY MORNING IS PROBABLY BEST. Get used to and accept some performance penalty for dirt and the guano factor. -
Spikes are NOT the answer to nesting pigeons.
Don't waste your precious time and money on spikes in an attempt to keep birds, squirrels or other critters out from under residential solar systems.
Bird spikes prevent birds from landing and roosting on surfaces, they will NOT keep them from crawling under the system. Pigeons and other vermin simply push their way through, between the spikes.
"Exclusion" as the pest control industry calls it, requires a screen-type barrier.
You'll want to attach it without drilling into the panels themselves (or the roof), as this will void your warranty.
Several products, made specifically to meet this need, are now available. One such example can be found here: www.spiffysolar.comLast edited by Spiffy Solar; 06-29-2015, 03:02 PM. Reason: Took out specific details about my product/company (but added the link). .Comment
I would be careful about advertising on this forum without the approval of the owners.Don't waste your precious time and money on spikes in an attempt to keep birds, squirrels or other critters out from under residential solar systems.
Several products, made specifically to meet this need, are now available (one, in particular, is manufactured and sold by us).
Although I'll rent anyone my cat to chase away those pesky birds.
It's a fine line between providing useful, relevant information and "advertising." I'm checking with the owners now. I'm open to any suggestions for post edits, thanks.Comment
I think for this issue you can call wildlife removal Fairfield County CT services. They can help you betterly. One of my friends likewise had the same issue and after receiving their services, bird do not sit and make their home at the solar panel.Comment
Keeping pigeons off and out from under your solar panels is a multi-part process. First you actually need to make sure all waste is removed and the droppings are all cleared away. This is because pigeons will see droppings as evidence of a safe place to live.
Then you need to install barriers on the panels themselves to prevent birds from getting under them. Pigeons almost always live underneath the panels, so blocking access will almost always keep them away. Make sure you use solar panel safe materials, fasteners, and methods to keep the warranty in tact.
Sometimes you will get a challenge from different roofing types where there's still a gap that pigeons can get into. Here's a quick post on a pigeon barrier installation technique you can use to make sure your pigeon control efforts work on any roof type.
I hope this helps!
Please do not attach sales links to your posts.Comment
