  • william1954100
    • Sep 2013
    solar Power
    I have 2- 100 watt Panels.. 4- group 31 Batt.,, Have trouble can not run my fridge for 12 hours, 20 amp Controller,, and 1000 watt converter,, what Am I Doing wrong ? Help William
    Real simple you do not have enough panel wattage, controller amperage, or battery capacity to run the fridge. Same thing as you earn $10/day, but cost you $50/day to live. You are bankrupt. Difference is the Law of Physics is amoral and has no mercy or feelings.
      • 15210
      How many watts does you fridge take to run? Knowing that number will help you properly size you batteries and panels.
      You are probably using more than you are generating.
      • Wy_White_Wolf
        • Oct 2011
        • 1179
        Get a Kill-a-watt meter and run the frig with it for a couple of days to figure out how may watt-hours it uses daily. With that info and your location we could figure out the size of a system you need. Most likely your panels and batteries are way undersized.
        WWW
          If you figure the best $900 energy star fridges consume 1KWh daily, and your harvest with an overly generous 6 hours a day of prime insolation, is harvesting 1200 watt hours, you are still depleting the batteries daily.
          To run that load, you need:
          Pure sine wave inverter (mod sine = +20% motor losses)
          Harvest of at least 1800 wh (will depend on your hours of usable sun, generally between 10am and 2pm)
          4000 wh of storage (may barely carry you through 1 cloudy day) ( 12V @ 100ah =1200wh)
          You need at least 2x as many panels, properly matched to your charge controller, and likely a better controller - maybe need 2 of them.
          Ready. Fire. Aim.
            Ready. Fire. Aim.
            Ow!
