Can anyone recommended a setup to aereate a 300 Gallon pond, unattended, 24/7, using batteries and a solar panel? I have tried buying my own stuff (mentioned in the previous post), but it is not working and I am thinking about trashing the stuff I bought and starting from scratch.
Trying to run a 300 Gal pond aereator 24/7?
Really UNATTENDED and BATTERIES are mutually exclusive. If you can live with great aeration in good sun, a
little in poor sun, and none the rest of the time, its possible to match up DC pumps to adequate panels to run
without batteries. Bruce Roe -
UNATTENDED and BATTERIES are mutually exclusive? Wow, this is a pretty big disappointment. I had not considered that.Comment
Well, operating battery systems that are being do require some baby sitting or at least occasional monitoring of operating conditions. So, don't shoot Bruce, he only knows mostly what he's talking about.Comment
I will cut to the chase with no lip service and tell you what is needed based on your other thread.
Battery Capacity @ 12 volts = 40 AH
Panel Wattage required if a 12 volt battery panel using PWM 10-amp Controller = 100 watts
Panel Wattage required using MPPT 10-Amp Controller = 60 watts
Now you know why round 1 failed, everything was undersized.
Good Luck.MSEE, PEComment
Thank you. I will google these terms and try to understand your recommendation. Any chance you want to just give me a parts list, ideally with Amazon links and everything?Comment
Does this part list look to you like the right way to go? :
WindyNation 60 Watt 60W Polycrystalline 12V 12 Volt Solar Panel Battery Charger:
Genasun GV-10-Pb-12V, 10 Amps 12 Volts 140 Watts MPPT Solar Charge Controller for Lead Acid
12V 55Ah High Capacity Deep Cycle Battery for Solar Wind Panels
