Thanks for the help!!!
DC pumping from deep well to cistern...
WWW, what float switch do you recommend for a DC pump? I have a Shurflo 9325 with the 902-200 controller and a 100w 24v solar panel. I was considering the SJE Pumpmaster WPS float switch because it is for potable water, but according to the installation instructions it seems to be only for AC? Here is the data sheet:
My setup uses a Shurflo 9300 series pump with a 120 watt panel and a LCB. There is a float switch in the 350 gallon cistern. I use only about 80 to 100 gallons daily in the summer. Pump is set 160' down with a static water level of 66'.
Bryan
This is the one I used. Didn't check to see if it was not meant for potable water.
Bryan
They also have this one from Dankoff
WWWComment
