Hi Guys,
I see some of you keep asking same question here.I just want to share my successful case after try and error. Normal DC pump is either too week or too expensive. I use 3 of the pumps following to create a 800GPH flow for my 500 Gallon Koi Pond.
http://amzn.to/29wiaH8
I tried different pump before I settle with this one. This pump accept from 8V to 24V based on my testing. It is perfect for me to connect to solar panel directly. But the voltage will affect the flow rate. For direct connection, when provide around 18V, it can do around 300GPH. The reason I use this one since it can pump up to 10ft high while others in the market can do the same.
Just share some of my experience, feel free to ask any questions.
Thanks
Thanks
