Hello guys,
I'm new to the site and also new to all this solar panels world. A lot of things to learn.
I have a small property with a well and I would like to use solar panels to get some irrigation going. The idea is just some dripping irrigation system so it wouldn't have to run very often. Here's what I would like to do.
Install a submersible pump. I saw one in Amazon that is AC, 375 watts and 115 volts, it seems to be just what I'm looking for (I checked some DC pumps but didn't have very good reviews).
I would like to run the pump every two hours (just during the day is ok) for 10 minutes (that should be more than enough to fill up the tank (200 gallons) and for it to empty.
I would like to know where should I start.
If my math isn't wrong (It probably is), to run the process 6 times a day I would need to generate 0.375 kw/hr every day @ 115v, which means that if I get 10 hours of light a day (the property is in Costa Rica so the minimum is close to 11 hours) I should be able to do it with (roughly) 4 100w x 12v panels?
Now, I would need to store this energy between uses, is this doable with standard car batteries? how many would I need? which size?
I will also need an inverter, what type should I get?
For running the "program", would you recommend a timer or should I get some kind of sensor in the tank in order to decide when to start the pump? Is there something that I can use that will run the program when both things happen: the tank is empty (assuming a sensor there) and the batteries are full?
I believe I would also need something that would prevent the batteries from overcharging, what would that be?
What else am I missing?
Thanks a lot for your info.
- Will
- Will
