Hi
i am using a 3hp motor with a bh30 pump to fill a 10 000L tank , water big lawns and BIG veggie garden of about 2 - 3 acres. we get extended power cuts from 15hrs per day to 4 days ... , i pump out of a dam so as water levels change i need to move the pump. I have to move the pump and cable in to the security fence in the evening as it will get stolen if left out (i live in Zimbabwe, im sure that explains the lengthly power cuts and theft). Ideally i would look for a solar pump system that i can have permanently in the yard and it is able to pull water up from the dam about 200 metres in distance but with a height of about 10 metres. is there something like this that is available and affordable ?
I am also looking at starting an aquaculture project so will have a much bigger need to pump sizable volumes of water.
can any one help advise on if there is an affordable solution
thanks
thanks
