Hello, I am planning a new solar irrigation system and just wanted to see if I couldn't get some feedback. This is my first time designing a complicated irrigation system. OK here goes. The pump I am planning to use is a 1/2HP 1.5" discharge centrifugal pump   capable of pushing 40GPM @ 40' of head. The maximum head in my system is around 25' or less, and the maximum demand for water in my system is 32.72 GPM. I calculate that I will need a system capable of producing 30 psi in order for the water to reach the furthest watering zone. The main line is 1.5" discharge lay flat hose, each watering zone reduces to 3/4" supply and drip tape with pressure regulators. Now the first thing that makes me nervous is that the pump seems to be more than capable. I will have a main pressure regulator and 12 psi drip regulators in the system to control pressure, but it's the flow I'm worried about. I've heard that these types of pumps are somewhat designed to self-regulate flow, but to what degree I am uncertain...I wouldn't want to tax the pump too much by constricting too much flow. I did find that 1.5" seems to be the minimum diameter main line I should use due to velocity and pressure loss seen over long distances. Additionally, the system will be controlled by an irrigation controller which will turn on the pump and supply valve via relays (Still need to find one for the pump).
This is a solar design, so here's what I was thinking.
This set up would allow me to water for 2 hours, leaving the battery @ 50% charge. The system uses higher flow drip tape (.67GPM), so after the 2 hours of watering, I should have applied what is equal to a half inch of rainfall. The battery could take 12 hours to charge...if there is a lot of cloudy weather, perhaps longer (thankfully irrigation is not typically needed on these days anyway). Planning to water every two to three days depending on the weather....I'll shoot for 1 - 1.5 inches of (rainfall)/wk, unless it is really hot and dry.
Well, what do you think? See any conflicts?
- 100ah Deep Cycle Marine Battery
 - 2000w continuous 4000w surge Power Inverter
 - 90 watt Solar Charging Kit with 10 amp charge controller
