I currently have a SunPumps T-135 well pump in an well that is positioned 50 feet down.  The water level in the well is essentially at grade and the well is a part-time artesian well.  The pump fills a 2600 gallon tank that I use as a buffer for a much bigger pump that pressurizes a drip irrigation system.  The T-135 pump is a brush-type DC pump that (IIRC) consumes something on the order of 150W or so; however, the pump is apparently dying according to the readings that I have taken with my volt-meter and the advice from SunPumps. I have 4 T-105 batteries wired in series (24V), ~5.4 Kwh of storage.  I have 3 285W (36V) panels charging the batteries - they are wired in parallel, and I have a Xantrex C40 charge controller.
To make a long story, less long, I need to increase my flow rate from the well to fill the tank so that we can do two waterings per day. The well will support the increased flow rates, but the current pump is no capable of doing that and it's dying anyways. The increased fill rate will enable us to do two waterings per day and also the filling of the tank will occur during daylight hours. We are targeting a flow rate of 6-7 GPM, an increase from ~1.5-2 GPM using the T-135.
I have been looking at the Grundfos SP pumps because they are much less expensive than DC brushless pumps. This will require an inverter, obviously, and I have initially chosen the Samlex SA-2000K-124, 24V Pure Sine Inverter as it is 24V and relatively cheap and I have another Samlex inverter that has been working really well for the last year or so.
I am looking to use the 7S05-11 pump, 115V 2 wire. The Pump's documentation can be found here: http://us.grundfos.com/content/gpu/e...-SP-PG-001.pdf on page 22 and 23. This should meet my flow rate requirements and has a reasonable cost.
OK, so that's the background. Here's the questions:
1) In the pump's documentation it shows the power consumption "per stage", but the documents never define what a stage is. I am assuming that the number of stages = the number of impellers. Thus, the peak steady-state power consumption of the 7S05-11 should be ~ 0.05 * 11 = 0.55 Kw = 550W. This sounds about right, assuming that the pump is extremely efficient (i.e., that is only about 100W more than a DC brushless pump with equivalent capabilities). Does this sound right? Is my assumption about stages = # of impellers correct?
2) Would a 2Kw inverter (4Kw surge) have any issues with this pump? Can I go with a smaller inverter (e.g., 15000W).
3) Are there other A/C submersible well pumps with similar efficiency?
4) Assuming that the panels produce a "real world" 600W (855W nameplate) then it seems like the panels should be sufficient to run the pump and keep the batteries topped off. Does this seam reasonable?
Thanks!
PS - I realize that this pump will be a huge load on the batteries. The irrigation pump is panel-direct, so in low light conditions it will not pump out of the tank. Thus, the only time the tank should drain is when the sun is shining. In theory, the power should "pass through" the batteries and they should be fully charged much of the time. In any case, if this doesn't turn out to be true then I realize that I will need to replace the battery bank. The last watering of the day starts at 1 PM, so the tank should be filled again by approximately 4:30 PM. Finally this is only running during the summer, and there is still light out at 9:30 PM here in the summers.
Thanks!
