Installing Off-Site Watering Setup
The stickie takes into account what it takes to replace what you use daily.
It also takes into account the max charge rates for batteries not the minimum.
Off grid people also have and it is required for long periods of rain to have a generator and charger.
This will allow a periodic equalization charge to stir up the electrolyte in the batteries.
You will need to have some way of charging batteries other than solar to account for extended cloudy weather and to perform a
Periodic equalization charge or the batteries will stratify.
One way around this is to use AGM batteries. Which do not stratify.
I will add something to the calculator to account for minimum charge rates when I get some time.NABCEP certified Technical Sales Professional
Well, I'm not sure I could justify the added cost and reduced longevity of AGM batteries. I understand the stratification phenomenon. But this system is ideally supposed to be able to be placed out in a remote field for 6 months with minimum maintenance beyond checking to make sure it is pumping the water and keeping up with the cows. How long on average does an equalization charge last? I mean, is something that someone could go out in the field, do manually for 15-20 minutes and be good for the week or more? And could you do this by say, running a cable from a running truck's battery and a controller to the solar batteries?The stickie takes into account what it takes to replace what you use daily.
Assuming you had enough solar power available, could you not also do this equalization with solar panels?[url]http://getcraft.net/?ref=Bm5Om0rne[/url]Comment
If you maintain a bit of bubbling ( not boiling) it will be very infrequent
In your case perhaps once a month or less depending on what the specific gravity tells youNABCEP certified Technical Sales Professional
OK, since this setup preferably needs to be checked at least every other day anyway, the watering is not an issue. Is a 200 watt charge current (8A) enough to cause the necessary roiling? 'Cause the panel should on average be putting that into the batteries for about 2hrs a day.
Again, if it's only monthly a person can just go out and, say, connect jumper cables from a truck to each battery in turn for a minute? Since the system is 24V, each battery can be done separately by temporarily disconnecting them. Is a minute of 20-30A charge current per battery enough?
And does testing the specific gravity require a tester or something? something that I can grab for $50 or less to include with the system?[url]http://getcraft.net/?ref=Bm5Om0rne[/url]Comment
