I'm looking at converting the GE 5cu chest freezer to a fridge via a digital thermostat that will just turn it off and on to control the temperature. Problem is GE says it needs 15amps to start but I just don't believe them. I have a feeling their being safe at 15amps. This will be the deciding factor on which Inverter I use on my off-grid system. Does anyone own this unit and/or tested it for actual starting amps?
What are the actual starting watts for the GE 5cu Chest Freezer?
The newer Kill a watt meters will I believe tell you the starting amperageNABCEP certified Technical Sales Professional
Either that or if you can fin dout the compressor make and model you can then look up the LRA rating which will be close.MSEE, PEComment
