I'm looking into solar attic fans. My first question is why are all the solar attic fans such low wattage? My second question is do they make them that are gable mount so that I don't have to cut a big hole in my roof? Maybe an even better question is how much do attic fans help, if they even help at all?
Solar Attic Fans
how much they help is dependent on how the attic is ventilated now. But generally they are not worth much.NABCEP certified Technical Sales Professional
I have 3 solar fans from Home Depot, mounted and sealed to the roof under 3 of the 5 "metro" metal roof vents. I have a continuous soffit with ducts between trusses.
I attached 60 watt panels to each of them. They spin fast.
My attic has radiant barrier on top of the fiberglass insulation and my attic temperature has lowered substantially.
135 degrees was common in the summer, now it doesn't exceed 105.
They have been in operation for over 14 months, I feel they will pay for themselves over time.
I'm in South Florida, Your mileage may varyComment
Up in the north country of New Hampshire an ac fan really didnt make much of difference in the gable ends vents. When I did a new roof I cut a continous slot the length of the roof and put a vented ridge cap on top of it, that made far more difference than the fan ever did.Comment
60 watt fan
Can you please point me towards a dc fan that home depot sells that takes 60 watts?
I had that from 1991 until 2004, then Hurricane Francis blew sideways rain into the vent and flooded the attic. Hurricane Jean tried to as well, then in 2005 Hurricane Wilma blew the shingles off the roof flooding it again. We reroofed with metro roof products metal roof shingles with vents. Ridge caps are becoming scarce in Florida since the Hurricanes.Up in the north country of New Hampshire an ac fan really didnt make much of difference in the gable ends vents. When I did a new roof I cut a continous slot the length of the roof and put a vented ridge cap on top of it, that made far more difference than the fan ever did.Comment
Master Flow 500 CFM Solar-Powered Gable Exhaust Vent is what I used. I tossed the 10 watt solar panel and substituted one Solar Panel 60 Watt 12 Volt Polycrystalline Silicon PV from UL Solar. It only gets full panel amperage for about 1 hour.Comment
one solar panel to power two fans?
If I have a single 120w solar panel, can I safely power two of these fans?Comment
Hey Tony, up in NH if the conditions are right, I get snow blowing in the upwind gable end vents even though they are louvered. I have a big plastic tray that hangs below it to catch the snow so it can melt and evaporate before it gets into the insulation. With snow, the ridge vents can get covered with snow and stop air circulation up through the soffit vents causing ice daming, thus the gable end vents. I guess regional conditions always factor in.
Take a look at the Whirlybird attic ventilators, just a slight breeze and they spin removing humidity and hot air from the attic.
Do you know what we call those in South Florida? Hurricane openings!Take a look at the Whirlybird attic ventilators, just a slight breeze and they spin removing humidity and hot air from the attic.
http://www.ehelpfultips.com/do_whirl...vents_work.htm
The new roofing codes won't even allow them to be installed. No roofer will touch those in South Florida.
They are not for everyone! Most likely no roof penetrations in hurricane country are acceptable.
They work great here in NY.
How about vents for a detached garage?
The use I have in mind is actually for a garage which has only small passive louvered gable vents. In the summer it gets really hot and makes the workshop area almost unusable.
I can put money into radiant barrier insulation on the inside of the uninsulated open truss roof, or powered gable fans, or something solar. Any thoughts on the respective merits of each? (Almost forgot: Currently there are no floor level or other vents in the walls, but I do have screened windows on the shaded side that can be opened if I remember.)
(I have seen discussions of line-powered fans that say the Home Depot type will only last a few years, but touting a $400 line-powered German model. Are there lifetime issues with the solar-powered DC motors?)
The summer outside temperature does not get much above 100 on the worst days, but the inside of the garage can easily get 20 degrees or more hotter at head level and intolerable up near the roof.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
