So, I'm trying to think of creative ways to use a solar panels in my backyard. One idea that I have is to slowly turn my compost tumbler with a solar panel. It's a heavy compost tumbler that I made from a wine barrel. I'm wondering if a 120 watt panel and some low rpm motor could do this? The motor would just barely have to turn and if the tumbler only turned around once an hour or so, that would be enough. Any ideas where I could find a motor that might work for this application? Do all motors need voltage regulators?
Solar Powered Compost Tumbler?
What you would be looking to get would be a gear motor or a high torque motor. A car starter would work but the amp draw on that is huge. Perhaps one from a motorcycle and a timer to turn it on once or twice a day for a minute or so.
You will need a panel, battery and charge controller in addition to the motor and timer.NABCEP certified Technical Sales Professional
I've thought about this one too. The problem always hit the same snag. Gearing it down enough.
My final thoughts where to forget a slow turning system. Instead use a car starter and timer/relay to turn it for 30 seconds every hour or so. Then your panel needs to be just large enough to recharge the battery.
Never built it thoug as I was also conserned about the safety aspect or it. Wouldn't want it to start up when somone wasn't ready for it or an animal was in the way of getting caught.
WWWComment
I am a fairly avid gardener and make my own compost. Even had one of the barrels some time ago. If you want to do it is just fine but quite a bit of overkill and defeats the purpose of make your own compost.
To make compost you do not want it to turn continuously or even once per day, but rather about once per week. It has to be allowed to site and heat up before it gets aerated. A simple hand crank will do the job to turn it over.
One way you could do it is use the gearing off an old bicycle and chain with a small dc motorMSEE, PEComment
compost tumbler
Thanks for the input everyone. I did find one other person who made an auto tumbler and posted a video about it. This is AC though and it's a bit of an overkill. I think I could make one with a small panel and a good sized battery. I could also use the battery to run other things when the compost tumbler isn't turning. And, you're right, you don't need to turn the compost that often as I have now learned. What batteries are people using out there? Are there any good lithium batteries on the market now?Comment
Please do not be under the impression there is anything at all green about what you want to do. It is exactly the opposite of green.Thanks for the input everyone. I did find one other person who made an auto tumbler and posted a video about it. This is AC though and it's a bit of an overkill. I think I could make one with a small panel and a good sized battery. I could also use the battery to run other things when the compost tumbler isn't turning. And, you're right, you don't need to turn the compost that often as I have now learned. What batteries are people using out there? Are there any good lithium batteries on the market now?[SIGPIC][/SIGPIC]Comment
