Using Kodak Tri-X on a bright, sunshiny day requires f16 at 1/500th of a second. Using that film on an overcast day might require f5.6 at 1/250th of a second or 16 times the combined amount of lens opening and open shutter time. So I'm guessing that a 60/hr watt solar panel puts out roughly 4 watts per hour on such a day?
Equating camera settings to panel output
f stop brightness is not the same as sun incident angle. the more perpendicular the sun is to the panels, the more power.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
So while cameras and solar panels don't really have anything to do with each other, my estimate of four watts was in the ballpark. So you'd have to have about 15 panels just to run a 60-watt light for a few hours on a rainy day.Comment
my 3000 w array, produces between 200-400 w in overcast sky.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike90250, what do you power with this set up? From reading your info at the bottom of your post it sounds like you have a nice setup.Comment
Large shop with many tools, arc welder, and irrigation pump that runs several hours a day in dry weather. Hopefully, in 6 months, it will also power my house.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike90250, are you expanding either or both, your array and storage or are they already enough and your house just needs rewiring? Years ago, I read that an LA Angels game was postponed because of rain. The PR staff had to go on a real hunt to find out when the last baseball game there had been rained out and it turned out to be a minor league game in 1957. So what percent of the days there are clear and bright? Is there a website somewhere that has this information for all areas of the country or would I have to ask a local TV weatherman?
On another note, in my old newspaper I read a report on the recently completed Georgia General Assembly about The Georgia Power Company quashing a bill which would have made it easier for people to be their own power company through solar panels and save money. I couldn't help but laugh because rural Georgia legislators have a long history of bashing the power company. The senator we had when I owned the newspaper, Roscoe Dean, would talk bad about the company wherever he went to give speeches. A Georgia Power exec laughed when I told him about this and replied, "But he never once voted against us."Comment
system A. Grid-Tie house in the city, with a 4.5KW west facing PV array. It zeros out my electric bill, except for monthly connect charge.
system B. Off-Grid Shop and House (house under construction -plans in permit process) will be running off a 3KW array, and a 42,000 WH NiFe battery bankPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
