120V AC (MSW). My freezer is presently the only Energy star qualified 5cu ft on the popular market and cost only $162 from Walmart. I have two identical one as fridge and one as freezer.
Freezer for Off Grid PV
1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
I will respect other peoples threads and try to stay ON TOPIC. Equally if I start a thread, and in order to keep forum friction to a minimum, only constructive ON TOPIC responses will be answered. Should I still don't reply: It is likely I have blocked you. for being B.A.D. (Belligerent And Derisive) -
Like your original post
Pete;
I don't know about numbers...
but your ideas to save energy with the two chest type freezers makes sense to me.
thanks for sharing..
BrofigComment
make a fridge freezer
is it possible to make a fridge and freezer if you have the compressor. in the philippines everyting is expensive and I was wanting to go on a mainly 12vdc system to make the required box etc with a lot more insulation than a typical store bought unit would have might be more beneficial as long on you have the appropreiate space any idea's ie what kind of compressor etc I hear there are some of the new compressors that are extremely efficient an take a lot less load to kick them into gear in order to do the job
thoughts pleaseComment
Yes this is done on boats all the time.is it possible to make a fridge and freezer if you have the compressor. in the philippines everyting is expensive and I was wanting to go on a mainly 12vdc system to make the required box etc with a lot more insulation than a typical store bought unit would have might be more beneficial as long on you have the appropreiate space any idea's ie what kind of compressor etc I hear there are some of the new compressors that are extremely efficient an take a lot less load to kick them into gear in order to do the job
thoughts please
Look at marine refrigeration preferrably with hold over plates so it only has to run during the daytime.NABCEP certified Technical Sales Professional
