I am new here but I have just discovered the "Ignore button" It is a wonderful tool.
Inverter(s) tripping
1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
I will respect other peoples threads and try to stay ON TOPIC. Equally if I start a thread, and in order to keep forum friction to a minimum, only constructive ON TOPIC responses will be answered. Should I still don't reply: It is likely I have blocked you. for being B.A.D. (Belligerent And Derisive) -
If anyone could show me a reasonably priced inverter that won't trip at 15.5V I would buy it.
PS. I worked in the Attaturk area for a while I enjoyed the food.1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
I will respect other peoples threads and try to stay ON TOPIC. Equally if I start a thread, and in order to keep forum friction to a minimum, only constructive ON TOPIC responses will be answered. Should I still don't reply: It is likely I have blocked you. for being B.A.D. (Belligerent And Derisive)Comment
Hmm, odd. The 12V inverters I have experience with:Normally it is fine but when a charge controller changes to ABSORB the current also soon dimishes. When fast moving cloud changes MPPT voltage from say 14V to 14.8V at reduced charging current it will often overshoot for a fraction of a second. My Flexmax 80A (Australian) controller frequently records 16V and in this situation enough to trip all 3 of my inverters. Also 15.5V is required (for most flooded battery banks) to equalize. this will trip just about any inverter.
Trace SW series DC voltage 11.8 to 16.5V
Prosine 2.0 10-16V
Outback FX2012 10.5-17.5V
Xantrex Freedom SW 3012 10-16V
But I suppose some inverters might have trouble.
Wouldn't work for any of my installations. For a 2000 watt load that's a loss of 140 watts in the diode. That's more cost, power loss and heat than I'd want to try to deal with in a system designed for long term operation. But for smaller systems it might be a simple fix for an inverter problem.There is a simple fix (thanks for asking) Installing a Silicon diode between the battery bank and the inverter(s) will drop the voltage at the inverter(s) by 0.7V.Comment
Mine; Power max TSW 15.5V
Aims 15.5V
Vector 15.5V
All trip above 15.5V for more than a second or so.
The inefficiency in my 1600w system is not really a problem as it is used only a total of about 5% use time so the 5% loss becomes 5% of 5%.1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
Russ, I am impressed you did leave my comment, so in fairness to all I removed it.1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
many of the cheaper 12v inverters do trip at about 15 to 15.5 v especially TSW ones. Most but not all quality 12v inverters dont trip below 16.5vComment
It is not arrogance, it is experience. Between John P and myself we have over 70 years combined electrical design and technical experience. Throw Mike, Russ, and Rich into the equation and we have over 100+ years of experience
So far you have not added any value. You lack basic knowledge and design concepts of solar power systems. So far you have given bad advice which is why you are rebutted. Those with experience are not going to allow you to get away with it. One example is you do not know the difference between a watt and watt hour., or how to calculate either value. watts and watt hours are two of the most important specs in an electrical system and if you do not completely understand that you have no biz giving advice.MSEE, PEComment
Good to know, of course I am stuck with mine now but one day I might just upgrade to a 24V or 48V system, that would be the time.1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
Britishpete really a diode is not the answer to solving the overvoltage problem, The losses are great unless you are going to be manually switching it in and out of circuit. That is a pain.And you are making the inverter draw more current than usual .Lower input voltage must draw more current than higher voltage for a given output wattage.
Think about getting an adjustable controller. then set it to 15v. its a cheaper solution than going to 24v ,unless you intend to vastly increase the system size. 12v has advantages. there are more easily obtainable devices than 24v ones.
The only time I think people should have a diode in the input side of the inverter is to fool the inverter to shut down sooner than they usually do. Nearly all 12v inverters have a low voltage shutdown of between 10.5 and 11v . Far to low to save the battery. But this really is a design fault of the inverter .While it would help that problem ,it creates its own problems.
Also remember what Sunking said. Dont ever give a statement like "it uses 180w". You always need to use watt hrs. ie 180whr. Think about how your grid meter reads power ie 1080kwh..Comment
Actually I have a controller with multiple variable user parameters including shut down at user defined voltage (mine is set to 11.8V with reconnect at 12.1V) BUT I think you are missing my point; In order to fully charge the batteries within sunlight hours I need more than 14.8 volts once a week. There is no jumping up and down I just put the diode in circuit for 2 hours once a week. Losses are really irrelevant as the power would otherwise not be flowing to the batteries anyway once they are on absorb for an hour or two. So I wait until charging current falls off to about 20 amps (on a 1000AH bank) then increase voltage to increase charge amps to 30A (decreasing) for the last 2 hours.
For me it works perfectly, and is very little hassle.1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
Ref yourt last, this is what I wrote;
Convert a chest freezer! I did and use only 180W per day average.
Now technically I included a time base (day) so this now becomes a measurement of total power (energy consumed in 24 hours). 180 watts per day or 180Whrs per day = same thing.
Without a DAY or HOUR or whatever other time base I agree I would have been incorrect.1.6Kw of PV, Outback FM80 controller, 40A PWM cheap Chinese controller, 12V 1000 AH of Trojan T105RE batteries, 2.5Kw Aims MSW inverter and 400W TSW inverter.
I rest my case you do not know the difference between watts and watt hours. They are not the same thing.
Watts = Power = Voltage x Amps
Watt Hours = Energy Consumed or delivered = Watts X Hours = Volts x Amps x Hours
Huge difference.MSEE, PEComment
Now technically I included a time base (day) so this now becomes a measurement of total power (energy consumed in 24 hours). 180 watts per day or 180Whrs per day = same thing. [/QUOTE]
180 watts average per day is 4.3 kilowatt-hours per day. This is a pretty common question in PV - "how many kilowatt-hours will I need if I use 100 watts a day average?" 100 watts is power; the answer they want is 2.4 kilowatt-hours per day, which is a measure of energy.Comment
