I nearly died laughing the first time I saw that video. Ya gotta admit. that's one helluva motor. It never did quit.
lets talk sbout appliances
coouul !!
Looks like a nice neighborhood too !Leave a comment:
LOL! No, ours would just stop and give an out of balance error code.Leave a comment:
We have one of the "exploding" Samsung top load high efficiency washers that we are overall happy with. The problem with these things is that their suspension rod/spring assemblies weaken with age which causes the machine to go out of balance at the slightest excuse. Usually, the machine senses the out of balance and just stops but I guess on occasion, they just keep going until something gives and pieces start to fly. For $80 or so and a half hour's work, I bought and installed new rod/spring assemblies and solved the out of balance issue. Samsung's offer to give us $35 to put towards a replacement machine was laughable so we had them install their "fix", part of which was supplying us with a new cycle label that hid the original "bedding" cycle (which had a medium spin speed) and renamed the "delicates" cycle "delicates/bedding." The delicates cycle with its low spin speed doesn't really do a good job on bedding so we continue to use the old bedding cycle for comforters.
We like the top loader without the center agitator because it easily takes a large comforter. We've also not found the top loader to be susceptible to the odor that is so common in front loaders.
We love the gas dryer too and would recommend it for anyone with gas service. It's especially great for anyone on T.O.U. and/or Demand electric rate plans.Leave a comment:
I stick with my Staber, US made with no transmission and a mechanical timer. Its a horizontal axis washer but a top loader and its spin cycle gets out a lot more water.Leave a comment:
Here is a category you can actually buy American, with confidence. And buy it from a big box that gives you 90 days to return it. And you'll figure out if you like it or not .top-load Maytag with no screw ,senses water amount like all of them probably claim to. You have heard of the Lonely Maytag repairman?Leave a comment:
My clothes washer is an old, creaky, and stinky GE WBVH6240F frontloader, so I've been slowly shopping around for an efficient washer/dryer pair.
The best search tool I know of is enervee.com, which lets you search by water use, energy use, size, and/or total cost of ownership. Rather spiffy.
But it finds some things that might not be available locally, so don't get too excited about a model until you verify you can actually get one.
lowest.com is my second favorite one, it's more realistic about showing things actually on sale, and it has pretty good search filters (including a CEE Tier one which may help pick up efficient ones).Leave a comment:
The Maytag Maxima X has a nice little review here: http://solarhomestead.com/clothes-wa...off-grid-home/Leave a comment:
Same as mine. I think it sucks. So does SWMBO (think it sucks). I hate contraptions that attempt to do my thinking for me.Kilowatts says my Maytag Bravos 4.3 cubic foot top load direct drive was an energy saver. Took so little power, learned quickly not worth trying to run with a small off-grid system. Its senses the weight and adds the right amount of water. Commercial technology 10 year warranty, made in the USA. Or pay $200 more for a really good lucky Goldstar or Samsung.Leave a comment:
I try to slip under the radar and not look like a multimillionaire Mensa member, so, these days, I mostly look/dress like Sam Elliott's character in "Roadhouse". First impressions count. Since retirement, no one has accused me of being a slave to fashion.Leave a comment:
For a very energy and water efficient washer, have a look at the Maytag Maxima X.Leave a comment:
If it's 'screw' type washer it quickly puts holes in your clothes so you're always up to date on fashion side
More common clothes washer in europe is a front loader. Most common in U.S is top loader. I had a front loader in the '70's- '80's. (Amana). Used ~ 12-13 gal. H2O/load and never broke down. Cost ~ 50% more than top loader. At the time top loaders used ~ 30-40 gal. H2O. My current dishwasher uses 4.6 gal. H2O/load. My current top loading clothes washer uses ~ 20-25 gal./load and is a PITA to use. Better in H2O use than old top loaders, crappy on facility of use.
More common clothes washer in europe is a front loader. Most common in U.S is top loader. I had a front loader in the '70's- '80's. (Amana). Used ~ 12-13 gal. H2O/load and never broke down. Cost ~ 50% more than top loader. At the time top loaders used ~ 30-40 gal. H2O. My current dishwasher uses 4.6 gal. H2O/load. My current top loading clothes washer uses ~ 20-25 gal./load and is a PITA to use. Better in H2O use than old top loaders, crappy on facility of use.The most efficient washers are found among the ranks of front loaders. They can agitate clothes safely with a minimum amount of water since the clothes do not have to be fully submerged.
The direct drive speed controlled motor models make for better energy efficiency too. They also feature a high spin speed to reduce the dryer energy needed.
The solar dryer (poles and a line) will be the most efficient possible when the weather is right.
