My first post and first 'toe in the water' solar project... I want to run an air pump with air stone to aerate a a well at our summer place, to try to freshen the water a little and hopefully also remove some iron deposits int he water. We don't use the place all year round, and it's not critical, so the pump can run sporadically (when the sun is shining) I am buying an air pump usually used in Koi Ponds, a Resun MPQ-902 38L/MIN 0.06MPA 18W 12V from China, and I have assumed that a simple DC motor could be connected directly to a solar panel, on the assumption that the pump will run when it is sunny enough, and will not run when it gets too dark.
So my question relates to what size panel I should buy to drive a 12v 18w pump. Is there a risk of frying the motor if I go a lot bigger than the 18w the pump needs, or will a motor simply draw as much power as it needs? My gut feel is that I would go for a 30WP 12v panel, which from those I have looked at peak at 30w and about 17v in perfect conditions. I'm at 60 degrees north (Sweden) so I would prefer to over-dimension a bit as long as I don't risk damaging the motor.
I appreciate your input!
