Electric hot water heated load calculations: Calling the watts and amps gurus
For propane tanks I'd suggest search for a large tank from a propane powered vehicle or motor home. They're mounted horizontal so less problems hauling them. mount it permanently on a small trailer and you wouldn't have to worry about loading or unloading it.
WWWLeave a comment:
I grew up in Red Lodge.Originally posted by hammickThanks White Wolf. I'm in Carbon County so we probably have similar PV performance.
These posts have convinced me to ditch electricity for any heating or cooling uses.Leave a comment:
I almost entered a drawing at our county fair for a free propane tank refill (up to some size limit like 500lb). Then I realized that I could not collect if I won since I do not own my tank.
On the other hand, the piping service (including switching to two stage regulation when we added a propane dryer) from the LPG vendor was quick competent and well priced.Leave a comment:
Buy the tanksOriginally posted by hammick
Checked with the local LP supplier. I can rent a 120lb tank for $50 per year and then propane refills are .99 cents per gallon. They install the tank on concrete blocks and pressure test system. Sounds like the way to go. Thanks for all the advice.
Renting them locks you into what ever they want to charge. Expect it to go up dramatically.
But you can only have them filled by them so you pay whatever with no opportunity to shop for less costly propane.Leave a comment:
Never ever store propane inside.Originally posted by hammickAll right you have convinced me to look into propane. I'll probably want to have a fridge at some point other than in the travel trailer and propane can run that also. Maybe also a gas range. Can a 100lb tank be transported full on it's side in the bed of a pickup? Can a full tank be stored inside an un-insulated garage?
Thanks for the good info!
Is theft really a problem?
If you insist on storing indoors you should build a vapor proof wall to separate the rest of the structure from the tanks and place some vents high and at floor level to the exterior.
Also no access from inside to tanks put in an exterior door.Leave a comment:
Forget the PV for heating water. Thermal is easier, cheaper, and more efficient. I have a weekend cabin in central Montana (Bull mountains) and we use a couple cheap solar showers for our hot water and only have problems on real cloudy days. Then we just heat what is needed on the stove.
The heater may only draw 8.33 amps at 240volts. But that is 41.66 amps at 48volts. When Peukerts Law gets takes effect you don't have enough battery to keep the voltage stable for more than an hour.
WWWLeave a comment:
I store 2 100lb tanks, one in a metal shed, the other in a garage, both are not climate controlled. I transported mine standing up in the bed as they have pickup tubes which could snap off if transported horizontal. 40lb tanks might be an option if it is just you to move them around, the 100s are kinda heavy when filled.Originally posted by hammickAll right you have convinced me to look into propane. I'll probably want to have a fridge at some point other than in the travel trailer and propane can run that also. Maybe also a gas range. Can a 100lb tank be transported full on it's side in the bed of a pickup? Can a full tank be stored inside an un-insulated garage?
Thanks for the good info!Leave a comment:
You're going to have to embrace the lifestyle then as you can't live a modern life on 1Kw of panels. How about 2 black 55 gallon olive barrels which are elevated and gravity feed sun heated water as a shower?Originally posted by hammickI would have to buy or lease a propane tank. Propane is expensive, especially in remote ares. I'm not sure if a 20 gallon propane tank would last two weeks. A refill is about $20. My property is about nine miles off the highway and is remote. We travel mostly by ATV once we are on the property. Not going to haul a 20 gallon propane tank on the ATV.
I'm open to people's opinions on propane for hot water though. I have looked at the various tankless models that would work with a 20 gallon propane tank and none of them look promising.
My thoughts on a tradition electric hot water heater (assuming solar will power it during the day and my generator at night) is that it's fairly cheap, I can install myself, easy to turn on when needed and water in tank stays warm for a long time during summer temps. Also super easy to winterize.
FYI, a new 100LB propane tank is 120 bucks from tractor supply, good for 12 years, cost 100 bucks to fill it at a propane filling station.Leave a comment:
It should. Nice thing about inverter pumps and inverter mini-splits. (Although the mini-split still requires agile thermostat handling to keep the temp differential from going too high!)
Getting back to water heating, the on-demand heater has the advantage of "limitless" time if not flow rate and no wasted hot water left over to cool.
But the camp size tankless seem to have some reliability and flame loss problems.Last edited by inetdog; 07-14-2015, 05:19 PM.Leave a comment:
It is a Grundfos pump with soft start so I'm hopeful the inverter will handle it.You will need approximately 3000 wh ac to heat 20 gallons of water from 55 to 115 degrees.
You more immediate problem is you water pump, the startup amp draw on your pump is over 30 amps and I don't think that your inverter or your generator will be able to supply the in rush current required to start the pump. I had a 3500/5000 watt generator and it struggled to start my 3/4 hp pump rated at 8 RLA.
I switched to a 5500/7000 generator and the pump starts normally.
The Generator recommendation for my pump is 50% over P1 power input or minimum 10% over P1 power input. P1 power input of the pump is 1.65kw.
The Conext SW4048 has a surge rating of 7000 watts for five seconds at 77 degrees farenheit.Leave a comment:
1st VERY SWAG on ground H2O temp.:~~ 90 - lat. in temperte zones. In warm weather, preheat H2O in amb. air if possible. Some experimentation is usually necessary/helpful.Just guessing but I think no more than 20 gallons of hot water a day. Tank will be very close to shower. Not sure of temperature of water as I'm in the building process right now and well pump is not installed yet. Pump will be at 119' in well. 5000' elevation in South Central Montana.
We can usually get our six gallon propane DSI water heater in the RV hot enough for a shower in 10 to 15 minutes so I'm hoping a 20 gallon in 45 minutes or less.
More SWAG: ~~3 to 4 kWh of elec. for 20 gal. Add 10% or so for losses to time/environment.Leave a comment:
Just guessing but I think no more than 20 gallons of hot water a day. Tank will be very close to shower. Not sure of temperature of water as I'm in the building process right now and well pump is not installed yet. Pump will be at 119' in well. 5000' elevation in South Central Montana.Since you ask, one thing I see missing: Most system sizing usually starts by specifying a load, that is, how much H2O you want/expect to use and how cold the H2O is when the heating process starts and how hot you want to get it. Also, some idea of tank and maybe line losses. Hard to design something until you know what it needs to do.
We can usually get our six gallon propane DSI water heater in the RV hot enough for a shower in 10 to 15 minutes so I'm hoping a 20 gallon in 45 minutes or less.Leave a comment:
You will need approximately 3000 wh ac to heat 20 gallons of water from 55 to 115 degrees.I am installing a 48v solar system on my off grid garage with small living quarters. I know electric hot water heaters are energy hogs but I'm hoping to get away with it by only running it during solar production or if we need it at night by starting the generator. It will be a 20 gallon Kenmore 240v with a 2,000 watt element. By my calculations it will draw 8.33 amps. Am I missing anything?
System info.
Four 275w panels (estimated to produce 16a of current at 48v).
Conext 4048 inverter
Conext XW 60 MTTP CC
Eight Insterstate 6v GC2 batteries (208ah)
Yamaha EF2400is generator.
My next biggest load after the water heater is a 230v well pump that draws 8.4amps We will have a larger pressure tank so the pump doesn't run as often. We would turn off the hot water heater before showering so the pump and hot water heater don't cycle at the same time.
I switched to a 5500/7000 generator and the pump starts normally.Leave a comment:
You have a system pretty close to mine, I'd be looking for another way to heat water as any resistive electrical element and 1000W of panels don't go well together. You've got a system designed for 2.5Kwh/day by conventional design parameters, some days you can harvest 5Kwh from the panels but those will be more rare than not and the "extra" would only run that water heater for an hour and 10 minutes.Leave a comment:
