Solar panels are semiconductors much like a diode, transistor, or IC chip. They start with a thin slice of quartz that is masked, then an etchant is used and they are built up in the same way any semiconductor is. They are very sensitive to EMP, even RF radiation. Solar panels stored inside metal buildings may work after a large EMP.
Abe
Solar powered AC air conditioning, a bummer or a challenge?
AbeLeave a comment:
200 AH is meaningless without a voltage. So I can only assume you are talking about 6 volt 200 AH golf cart batteries wired in series to make 12 volts. 12 volts x 200 AH = 2400 watt hours. For an off-grid battery system you size the battery to give you 5 days run time. In reality this only gives you 2.5 days as you never want to discharge the batteries more than 50%. Put another way you only discharge your batteries 20% each day.
Battery cycle life and Depth of Discharge is directly related. The deeper you discharge them, the fewer cycles you will get out of them. Here is a chart to display:
Discharge 20% each day and you get about 5 years, 50%just over a year, 100% just a couple of months. In your case using a 12 volt 200 AH is 2400 watt hours and you want to drain 600 watts x 7 hours = 4200 watt hours. Not going to work.
So your air conditioner uses 600 watts and you want to run it 7 hours per day. 600 watts x 7 hours = 4200 watt hours. That means you need a minimum of 4200 watt hours x 5 days = 21,000 watt hours or 21 Kwh. To find the battery AH capacity is easy Amp Hours = Watt Hours / Battery Voltage. So you get:
1750 AH @ 12 volts
875 AH @ 24 volts
438 AH @ 48 volts
To determine cost a good 5 year battery will cost you $220/Kwh and weighs roughly 55 pounds per Kwh. So for a 21 Kwh battery will cost around 21 x $220 = $4620 and weigh in around 21 x 55 pounds = 1155 pounds.
AbeLeave a comment:
Try crunching those numbers with a $5 or $10 AGM battery. Cell towers keep their battery topped off and cycled them out every one or two years. The battery still may last five to eight years after that. This will drop your battery cost down to the penny or two per kilowatt.
Abe
This is not a duct tape site where one is encouraged to cobble stuff together.Leave a comment:
I had an idea for my camper trailer build that May or may not work for it.
I saw a 12v air conditioner add on kit made for a truck that mounts under the dash. 7000 btu (I think).
Saws it on eBay. It would have to hang from a wall cabinet or something. I haven't found any info on weather someone has tried something like that in their home.
That would be cool if I could do that, but there would be many hurdles to overcome.
AbeLeave a comment:
Factual figures from one of my products.
$300 AGM Battery...
216WH daily use...
X 365 = 78840WH annually...
X 5years = 394200WH
/1000 = 394.2KWH of service life
$300 / 394.2 = 76¢ per KWH
^^^ and that doesn't include the cost of the panels, charge controllers, wiring and hardware.
Also, consider the battery may last only 3 years,,, raising the ¢ per kwh figure.
AbeLeave a comment:
I'm not one of those geeky prepers who keeps a bug out vehicle, and a cabin in the woods with 1000 pounds of canned food. But if the US dollar ever collapsed, or I there is a super virus outbreak, or Iran takes us back to the Stone Age when they develop an EMP device, then I'd rather not be one of those who died immediately because I didn't have a plan B.
If a low cost solution IS viable, then maybe I'll start looking into ways to make it more viable.
EG building my own solar panels, and batteries, improving circuit designs and building the components myself, etc. I am trying to start small but I really have a grand vision if it works out.
If you really want to learn about solar there are plenty of components out there you can bolt together and play with. You can quite easily build a small system to (for example) run some yard lights at night. You'll learn about battery charging, hours of effective sun, the role panel azimuth and elevation play, battery temperature compensation etc. And if you burn through a pair of GC2's in your first month you're only out about $300.Leave a comment:
That would be cool if I could do that, but there would be many hurdles to overcome.Leave a comment:
Preppers? I have been hearing that BS as long as I can remember - I am 69 so that goes back a ways.Leave a comment:
I build many 12 volt swamp coolers to stay cool here in california, humidity rarely gets over 50 so they work great. I always look at youtube among other areas to learn ways to improve on the design of the swamp coolers I make.
There was a design I saw on youtube of someone using a heater core radiator with hoses going into a ice chest filled with cold water, he had a fan blowing on the radiator. the pump circulated the cold water through the radiator. He had a thermometer showing a drop in temperature. This is a very primitive A/C. The only downfall I saw was feeding ice to the ice chest to keep it cold. In my mind I had and idea, what if you just filled a 12 volt fridge full of water and ran hoses from there instead of an ice chest. You would always have cold water without needing ice.
12 volt fridge only uses 4 to 5 amps when its running. Water pump uses 1 amp, you can use a endless breeze fantastic fan that produces 900 cfm of airflow at less that 3 amps as the air source. I know something like that would easily run off my 240 watt solar panel.
Your idea to get AC on solar/batteries is possible but you need to think outside the box and maybe build something on your own.
If I really needed AC, I would definitely build something like the above. For me it would be a challenge that I could not refuse, I would not give up too easily.
But also dont overlook swamp coolers, growing up in texas with high humidity and temperatures in the 100's, and giant mosquitos we never had an AC, all we had was a giant swamp cooler in the living room and that kept the whole house cool. You can build your own 12 volt one cheaply and they are very solar friendly.Leave a comment:
For your standby/emergency system you want a generator - not solarLeave a comment:
