Hi, I have a smal solar panel system with a 10W solar panel and 12V 7Ah deep cycle lead acid battery. I am only using it for a small 7W, 12V LED-bulb so i have not used an inverter for my array. I have a 12V socket outlet, but to charge my cell phone I need a 12/3,6V adapter (for different types of cell phones). I have only found the ones used in cars (http://www.maplin.co.uk/p/12v-mobile...ing-tips-a85la), but i want a normal plug for home use. Does anyone have a solution?
12V adapter for cell phone
If I understand you correctly there is no solution by design. Plugs are different to prevent you from plugging into wrong voltage supplies. You do not want a plug that works on both 12 volt DC and 240 volt AC.MSEE, PE -
My quastion was if there is an adapter which I can use for charging cell phones directly from the solar battery (12V DC) in the house. In my car I have a 12V cell phone charger and it has 12V input DC current, but I can not use a car plug in a regular socket outlet.Comment
Do you want something like this:
http://www.amazon.com/adapter-cigare...=12+power+plug
Cut the end off and wire to your battery.
WWWComment
Like Sunking said, I'm not understanding you either.
There are household current (AC) chargers
There are automotive chargers
You could purchase another automotive charger, clip the lighter plug off the end, and wire that (pay attention to the polarity + & -) with a fuse, to a battery in your house ??
Just not sure what you are asking.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
YOu home sockets are 240 VAC, not 12 VDC.MSEE, PEComment
Ok my bad. Maybe I got everything wrong.Do you want something like this:
WWW
I live in a small village and there is no electricity. I have a solar cell giving energy to a small battery. I also have a socket outlet (12V DC)
http://www.sparelys.no/index.php?pag...mid=1&vmcchk=1)
connected to the battery. Here is a picture of a power adapter both for car and for a normal socket outlet (to the left). I want the normal type, but I don´t know if the one in the picture is for 230/3,6V or if it is the same as the car adapter.
http://www.miniinthebox.com/no/car-c...FYNf3godNBYA4A
Normal power plugs have a AC/DC converter (such as a 230/5V AC/DC adapter: http://en.wikipedia.org/wiki/AC_adapter), but what I need is a DC/DC adapter/power plug (12/3,6V) which I can use directly from my outlet to the cell phone. Hehe not to easy to explain, but hope that somebody can help or even understand my question :PComment
Your best bet, in my opinion, is to use the available adapters which charge cell phones or other equipment from a 12 volt nominal battery supply (automobile, etc.) Their design input voltage will be cover the range from ~11 volts to ~15 volts, since the car electrical system under normal use can deliver voltages anywhere in that range.Ok my bad. Maybe I got everything wrong.
Then if you also need to use the same charger(s) when traveling, get the other standard adapters which convert the mains AC to 12 volts DC with a built-in automotive style power outlet.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Yes I think the best solution is to connect a normal adapter plug with a 12/5V car adapter and use normal cell phone USB adapters.Your best bet, in my opinion, is to use the available adapters which charge cell phones or other equipment from a 12 volt nominal battery supply (automobile, etc.) Their design input voltage will be cover the range from ~11 volts to ~15 volts, since the car electrical system under normal use can deliver voltages anywhere in that range.
car charger (12/5V): http://dx.com/p/jjt-080-12v-to-5v-ca...8#.UxBnfkJ5Pen
USB kabel wth different cell phone adapters: https://www.deal.no/deal/default.asp...FVKWtAodEAMAWAComment
I also found this plug which is a transition from normal plug to car charger plug
