Solar Powered Air Con- possible?
Winner Winner Chicken Dinner. Just about every residential whole house and commercial genny does that. Heck even some Gas portables like Honda "iAVR" system beets that. It comes down to design and matching components up that work with each other.MSEE, PEComment
That would only be the case with a generator just driving a charger. In systems (more typical) where the power passes thru to loads and the inverter can either charge batteries with excess or switch to invert mode to assist the generator with loads (Generator Support Mode), THD becomes a very real issue in keeping the generator qualified on the inverter. And sometimes in getting it to qualify at all.
We always figured that if we could get 5% THD at rated prime from a genset, that's about as good as it gets. But the point is that "thumpers" that deliver uneven torque do not make good prime movers for AC gensets. They're fine on DC.
Chrisoff-grid in Northern Wisconsin for 14 yearsComment
I built a PV/Peltier based cooler for the workshop.
If you're going to cool more than 50m3, forget it, use a generator.
My workshop is about 30m3, with a 150W panel, it cools about 10-15 degrees - not much when the ambient is over 40 degrees.DemComment
