Sunny days are here ! Just giving a quick update on status here at the ranch.
Our Rheem rooftop solar heater (the 47 gallon Solaraide Passive) is being fed with 60F water from our tempering tank.
This afternoon, after a reasonably short shower, the outlet of the tank was reading 135F water, that was being fed to our tankless stand-by/booster water heater. This makes our propane sales man unhappy, but I don't care.
This past winter, the stainless steel thermosiphon loop in our masonry heater, brought our tempering tank (80 gal) up to about 100F on a daily basis, resulting in preheated water feeding the tankless, requiring it to only boost the water 20F instead of 80F. Less fossil fuel again, only what's needed to chainsaw 3 cords of wood.
The only drawback, is that the rooftop heater on the 2nd floor, is about
40' of 3/4" plumbing away from the tankless, so that when a short dose of hot water is needed, there is several gallons of cooled water standing in the pipe that feeds the tankless. A single story install would have less water in the loop, and be a bit more efficient in that regard.
Our solar PV system (3KW) is much happier, now, no clouds, so no cranking up the generator in the mornings. We're consuming about 8 KWh daily right now, running the irrigation pump for about 2 hours (2KWh for pump) and the batteries are at float by noon most of the time. But in the winter, with clouds, I'd needed about an hour of the generator (about 2.5KWh, 2 qt of bio-diesel) daily, to keep the batteries up. Ambient solar was doing the rest, and careful consumption (sun's out, quick, start the laundry, OK to make toast) made the solar harvest stretch.
We've converted most of the lights now, to fairly decent warm white (2700K) dimmable and non-dimmable bulbs, with a couple of florescent circleline fixtures in critical areas.
The slow sand drinking water filter has been working pretty well,
and last years water test showed no pathogens.
tankless: http://www.eternalwaterheater.com/products.html
http://www.cdc.gov/safewater/sand-filtration.html
All for now.
Mike
All for now.
Mike
