I know the answer is "No" when it comes to designing a whole house system, but hear me out. This is just an idea for some inverter power for short bursts without using a battery bank.
If you wanted to run an inverter short-term to power AC tools in your workshop for an hour or two a day would the following work?
Use a PV array with plenty of wattage and connect that to a MPPT controller. From there run the output through a DC line conditioner, for example 10V to 16V in with 12.5V to 13.5V out, which then goes to your inverter.
Set the MPPT controller to equalization mode/conditioning mode so the voltage is a constant 15.5 volts for 8 hours. (one of the settings on my CC)
The idea would be that the larger array could provide adequate wattage to the charger which would then put out an increased constant voltage that would then be conditioned down prior to going into the inverter.
If you ran a setup like this for say 2 hours on a clear summer day during the peak of the day do you think it would work? Of course when you are done cutting your wood, drilling your holes, or whatever the task you shut it all down and save it for the next sunny day.
P.S. The above is assuming you were running a 12V inverter. Of course if the concept was sound then a larger inverter could be run at 24v or 48v by just changing the MMPT settings and using the right equipment and sizing the PV array appropriately.
