I have six solar panels on my boat, a total rated capacity of 420 watts. I had a Xantrex C35 controlling them. After 3 years of flawless performance it failed and fried the batteries. Now there is MPPT and PWM. The Solar City website gives the following information:
"Maximum power point tracking (MPPT) charge controllers will convert a higher voltage DC solar panel output down to a lower voltage needed for charging batteries. Constantly monitoring both the solar panels and the battery, solar MPPT charger controllers help you optimize your energy collection."
"Pulse width modulators (PWM) are a type of solar charge controller that slowly reduces the charging current to avoid overheating the battery after it has reached the regulation setpoint. At the same time, the system continues to send the highest amount of energy over the shortest period of time , which results in rapid charge and high efficiency. Essentially, a PWM charge controller helps to increase charge acceptance of the battery while maintaining high battery capacity for a longer period of time."
I've two sets of questions:
Which charges faster? Approximately how much?
It sounds as if maybe the PWM would protect the battery from overcharging better? Is it a :fail safe" technology, one that wouldn't charge at all if the controller failed rather than to allow an uncontrolled voltage to boil the batteries?
