Hi.
I have been reading the threads on this forum - they are very informative - thank you all for your wisdom so freely offered. In many threads there is discussion regarding how the deeper Lead Acid batteries are drained the sooner they have to be replaced and that this is a major maintenance expense in a PV based power system.
Is it possible, to configure a solar MPPT controller based charger system so that only the surplus current not going into charging the batteries is used to power a low-priority item such as a water heater. Is there a technical term for such a system or device (so I can search further). I am thinking that the surplus power could be used to power a water heater or well pump to a tank while the batteries remain topped up waiting to kick in to provide backup power for a freezer etc. In this way the batteries would see almost no cycling.
One way I could think of doing it is detecting that the MPPT controller is not sending amps to the batteries and then flipping a relay to activate the additional circuit. Do MPPT controllers typically output such signals? Or would I have to monitor the DC charging current out of the MPPT controller?
Another idea might be to let the MPPT controller charge the batteries and then simply monitor the charge level and flip a the second circuit in and out directly off the batteries - all the while only permitting a very nominal amount of discharge from the batteries. Does this seem a better idea from the perspective of battery life?
Any ideas on a ballpark estimate of how long a lead acid battery might remain viable if used in the above scenarios?
I am aware that the economic math doesn't add up if buying a system such as I describe from new. However, I have some of the equipment already (got it very cheaply second hand), I like doing stuff like this, and am exploring interesting ideas.
As a side note, I'm completely new to PV/solar/batteries but do have knowledge of electrics/electronics and hence am comfortable with DC/AC volts/amps Watts and VA and the associated math - so no need to sugar coat things.
I appreciate your advice.
