How do I measure amps produced by my solar panel?
I have a new Helios 6t-245 watt panel attached to a TriStar-45 controller energizing 2-12 volt deep cycle batteries, a 24 volt system. My TriStar-45 says, on a beautiful sunny summer day in north Idaho, that I'm getting ~30 volts but only .5, that is 1/2 an amp.
So, I took the controller out of the system and hooked the panel directly to the battery bank, inserted an ammeter between the negative lead and the negative battery terminal and it still only shows 1/2 an amp flow. Even if the batteries are fully charged, shouldn't the panel still put out it's best effort? I'm stumped!
Thank you for your help,
SJ
SJ
