Watts vs Volt-Amps - huh ??
This is a sticky topic.
I chuckled when I first read this post. This is pretty much a DIY forum and the posters looking for help have ZERO electrical knowledge and all this is is GREEK to them and will never understand one bit of it. -
simply put, watts takes the power factor into consideration:
Voltage X Current = volt-ampere
Voltage X current X Power factor = watts
to get the power factor:
PF = cos (angle) = adjacent/hypotenuse in the impedance triangle
You are correct my bad, I should have proof-read, I realized it a few minutes after the fact. Bit embarrassing because I taught Trig at a community college to electrical students. Should have the variables R, Rx, and Z and I would have not made that mistake.Respectfully submitted, since I am not an AHJ and therefore need to be polite:
The power factor is a/c not b/a. Otherwise it could end up greater than 1, among other problems. (Look at the simple 0 degree and 90 degree cases if you have any doubts. But I suspect it was just a typo on your part.)Leave a comment:
Well if you are a Carpenter, I can teach you AC theory in 5 minutes or less.
Any good carpenter knows how to make a perfect Right Triangle with a simple cosine equation. Bet you are not even aware you knew trig. Ready 3 + 4 = 5 Every carpenter knows this is a true statement and is cosine law you can prove to yourself right now with a piece of paper, a ruler, a compass, and a pencil
Draw a base line exactly 4 inches in length. With a compass set it to a 3 inch span or radius and place it on the left end of the 4 inch line and make an arc line straight above it at approx 90 degrees. Now set the compass to 5 inches, place it at the opposite end of the 4 inch line and make an small arc line that intersects with the other arc line you just drew. Now with a straight edge draw a line from the arc intersection to each end of the 4 inch line and see what you have. A perfectly 90 degree right triangle every time.
So here is the math or cosine law.
Try it where:
a = 4
b = 3
16 + 9 = 25
Now take the square root of 25 and you 5.
So there you go 3 + 4 = 5
So now just replace a with Resistance, and b with Reactance, and the result c is the Impedance. Oh the power factor is simple PF = a/cLeave a comment:
Well if you ever took trignometry it is very easy Right Triangle equations.
Resistance is the X base or horizontal line, Reactance is the Y vertical line, and the distance Z between them is the impedanceLeave a comment:
Most electrical references say that Volt-Amps are just the product of the amplitude of the voltage times the amplitude of the current, without taking into account the power factor. That is important in an inverter since it must be rated to deliver a certain number of amps even if no power is being transferred as a result.
AC watts are the actual power being moved, multiplying the VA number by the power factor (cosine of the phase angle between the Volt and Amp waveforms.)
For DC, both are the same, since there is no phase relationship to consider.
Both numbers are important in that a good inverter will draw down the battery based mostly on the watts it is delivering. But some cheap circuits will do worse than that. (Their efficiency will vary strongly with power factor, low power factor corresponding to lower efficiency.)
From your linked pdf:
"The power drawn by computing equipment is expressed in Watts or Volt-Amps (VA). The power in Watts is
the real power drawn by the equipment. Volt-Amps are called the "apparent power" and are the product of
the voltage applied to the equipment times the current drawn by the equipment."Leave a comment:
What's the difference ? Simplistically, Watts are for DC, and Volt-Ampres is it's AC equivalent. VA factors in the AC voltage & current when they are out of Phase, and is a more accurate standard of the energy being consumed.
Schneider Electric's APC division has many white papers & podcasts (see http://www.apc.com/podcast/ )
They are mostly trying to sell you a larger UPS, but the same factors are also present in off-grid housing, with CFL lights running off an inverter. Many CFL bulbs are.6 PF, which is really lame, when you have to have a lot of inverter overhead to run a little light.
Watts and Volt-Amps: Powerful Confusion (#15)
PDF: http://www.apcmedia.com/salestools/S...NQYF_R0_EN.pdf
MP3: http://www.apcmedia.com/podcast/content/wp/15.mp3
Enjoy.
