Ok..
I went to HF and checked out there solar stuff about a month ago..
They have angle mounts that are 14" long and can adjust to 35,45, 60 degree with pre-drilled holes.. and are $9.99 normally.. people on EB are getting like $15-25 for the same ones..
They are made for the small panels they sell.. however..
With a little work I drilled some holes and can goto 25' degree angle which is my spring/fall settings for my TX location.
Here they are temporarily screwed into 4 x 4's.. ($3-4 at HD for 8' length).. I was testing my 145 w panels which are 26 1/2" wide...
Because they are only 14" long if you want to extend them for middle of panel use you can simply buy some angle AL and drill matching holes.. or you can do like I did and weld angle STEEL from HD (if you have a welder)...I would suggest just bolting the new metal vs. welding.. really not worth the effort (realized when I was done)..
Before..
During..
After:
In the end though it was just easier to mount on the OUTBOARD edges.. and 14" is over 1/2 the 26" panel width and the fact these will only be about 10-12" off the ground and at 25' degree angle means more than likely a WIND will not get under them..
I plan on doing 1-2 layers of cinderblocks with J bolts sticking up and just bolting these frames directly to that..
Also I will have a small 3-4' fence around the array to keep out critters and such..
I just went back today and got 2 more sets for $8. and $8.55 using the 20 and 25% off coupons..
3 more sets for my 3 other panels and I'll be set..
Hope this inspires someone..
Before..
During..
After:
