Hello Everyone,
I have a very small system that is used for office lighting and mobile phone charging. I have a 12V 85W PV panel, a Morningstar SunSaver SS-10L Charge Controller and a 100Ah 12V AGM Battery.
I have an analog Volt meter that I have connected to the battery, so I can monitor the battery state. What I am planning next is to add an Ammeter to the PV side. I have ordered a digital meter that comes with a Shunt. I believe I am clear on how to connect the shunt and the meter, but was wondering if anyone could recommend on which side of the PV circuit I should hook it to.
My PV panel positive (red) lead is 12awg and runs from my roof to an inline 10A fuse, then into the Charge Controller(+). The PV panel negative (black) lead is connected to the Charge Controller (-) directly. If my intention is to monitor amps coming from the PV array, would it be better to install the shunt inline on the positive or negative side of the PV circuit? My instinct says use the negative side... but was wondering if anyone has an opinion, or does it even make any difference?
Thanks for any thoughts.
.w.e.s
.w.e.s
