So this isn't the 'how do I wire my bank' question - it's much more basic than that.
How do I connect a wire to my battery?
I've been using alligator clips, which work fine but are a bit... fragile. And I'm thinking of growing the system, so it's probably time I learn how to actually make a real connection.
I have two different connections on my two batteries - neither are posts like on a car battery. I guess the one (doing a bit of googling) is a Universal Terminal - basically a block with a hole in the middle. The other is just two bolts that screw down into the battery.
It looks like a lot of wire for batteries sells with a ring at the end, that I guess I could just run the bolt on the one battery through. The other one, though, clearly needs some sort of connector to make anything connect to it.
If you folks could help me out, point me in the right direction for, e.g., what terms I need to make google find things for me, or particular products that might get me going, I'd much appreciate it. As I said, the alligator clips are working for now, but it's going to get messy before too long!
(my system is 12v, and it's far from anything that could catch fire, in case you were a little worried that I was being let loose with electricity!)
Thanks!
David
Thanks!
David
